Not an Ariel sprocket but can I ...
john.nash
Post by john.nash »
These two are off my Indian.
Not cheap for a new one (and seems outof stock - so maybe not available) and both have plenty of life in them - unsure why the generator teeth are off, misalignment maybe ?
Can I simply build up the broken tooth (one tooth on one, three on the other) with my Mig (with stainless wire - bit harder) and then reshape with my lathe and a file ?
Failing that - there must be UK companies which rebuild unobtainium sprockets
SteveShone
Re: Not an Ariel sprocket but can I ...
Post by SteveShone »
Ive used John Hemming a couple of times - engine sprocket and brake drum sprocket of my Sunbeam Lion. The engine sprocket came back very quickly with 2 or 3 weeks though the brake drum sprocket took several months :| Both were excellently done jobs and reasonably priced. May be worth a ring to establish turnaround times.
01547 530781 sproxme@gmail.com Based inBucknell, Shropshire and advertises in OBM
Steve
