VB chaincase oil leak
Posted: Sun May 30, 2021 5:49 pm
Gents
One more request if I may. Took the bike on a spin in this glorious weather - very difficult to resist for sure. I took the opportunity beforehand to check the chaincase for oil - looked like hardly anything in there, dry-ish chain, and no drain plug to check for sure. Filled it with GP50 to well below the overflow hole - i.e. nothing came out from the overflow, and as I saw a spray mist of oil though the large inspection hole when the bike was running anyways, I bolted things up. Post run, I noted a weep of oil from the inside of the rear of the chaincase at around 2 o' clock. The nearside of the wheel was also coated in a film of oil. The chaincase joint looks sound. This was not happenning prior to my filling the chaincase.
Thoughts then
Where is the weep coming from? Difficult to see the rear of the inner chaincase, but I suspect the clutch/drive sprocket orifice.
Have I overfilled the chaincase? I consulted various manuals and it just says fill with enough oil so it escapes from the overflow. This seems too much. For the moment, I could fill it so it just touches the bottom of the chain. This is fine, but it is difficult to see the low point of the chain to judge.
Is there a drain plug for the chaincase? - bolted cast alloy halves by the by - not the pressed steel aberration! I can't see one - which is a bit odd, then again it may be me....
Many thanks
Mark
Thoughts then
Many thanks
Mark
