Finished article
JohnReilly
Finished article
Post by JohnReilly »
G'day all,
You may recall I posted a few photo's last autumn after purchasing a project KH500. Well I have used the coronavirus lockdown "doing it up" here is a photo. Started second kick.
robjameson
Re: Finished article
Post by robjameson »
Nice job, it looks lovely!
Rob Jameson
AOMCC Member Number 4068
1957 Ariel VH
1954 Ariel KH
AOMCC Twin Spares Organiser
Lovely! Something to look forward to, for when we are allowed out...
Post by Simon.Gardiner »
Very nice work there, John
(But please screw in the fulcrum adjuster on that rear brake to get the lever angle back to 90 degrees! ;) )
Eero.Korhonen
Post by Eero.Korhonen »
It is looking very good, well done!
Br, Eero
GuyH
Post by GuyH »
Nice one John!
1939 600 OHV 4F, 1956 MKII Square Four, a Healey, 1939 OH 250, 1939 OG 250 plus a couple of OG250 projects, 1920 Ariel V twin project and a variety of lesser makes
JohnReilly
Simon,
I have the rear wheel out and examining the brake so I will try and get the best adjustment possible.
I thought it was funny that the lever was vertically up but the spring only fits one way.
Thanks
John
John:
Lever needs to go up or the brake will pull on/lock if you hit a bump while braking.
Have you got all the fulcrum adjuster components in place at the other end? You usually just need to screw in the adjuster (with the rod adjustment slackened off initially) until the lever only pulls up to a right-angle when the brake is on.
JohnReilly
Simon,
I took the wheel off only because I thought the lever being "up" was odd. Thanks for the explanation.
Yes all the parts are in place and correct, I will adjust correctly next time. I was in too much of a hurry to road test the bike once
I got the engine running to think about the other fine tuning bits. Not ever having ridden anything that old I wanted to see what it was like
John
david.anderson
Post by david.anderson »
Well done and a lovely job. Its good to see another Ariel ready for the road.
