Project 1934 VG 500
Re: Project 1934 VG 500
Did you find anything stamped in the rim Albert? As Roger said, Lucas part numbers are stamped on the outside of the shell in the 6 o'clock position.
clearly a modern light unit and the headlamp is 7" as it is measured across the opening, but admittedly this is a bit fuzzy/confusing when reading the Lucas parts books.
No numbers or marks whatsoever on the headlamp… probably some indian replica..
Another thing to add to the list (if ever possible to source)
