Project 1934 VG 500
Re: Project 1934 VG 500
Did you find anything stamped in the rim Albert? As Roger said, Lucas part numbers are stamped on the outside of the shell in the 6 o'clock position.
clearly a modern light unit and the headlamp is 7" as it is measured across the opening, but admittedly this is a bit fuzzy/confusing when reading the Lucas parts books.
AlbertR
Post by AlbertR »
No numbers or marks whatsoever on the headlamp… probably some indian replica..
Another thing to add to the list (if ever possible to source)
