Page 3 of 3
Re: 1928 Front Gas Lamp Brackets
Posted: Fri May 15, 2026 8:27 am
by Roger Gwynn
The club has the drawings for both the 1927 version, D9/75 (6100-27) and for the 1928 machine E8/411 (6100-28) the latter shows that the taper is 1 in 5 inclusive or 5.655 degree angle
Posted: Fri May 15, 2026 5:24 pm
by cmfalco
Roger Gwynn wrote: Fri May 15, 2026 8:27 amthe taper is 1 in 5 inclusive or 5.655 degree angle
Aside from the issue of whether the angle per side, or the total angle, is being discussed, the test rod I cut on my lathe at 5.7° definitely didn't fit, while 5° almost did.
Posted: Fri May 15, 2026 5:58 pm
by Roger Gwynn
Oh yeas, always better to make the part to fit the other part rather than as specified as the former will fit and the latter may not
Posted: Sat May 16, 2026 8:26 am
by nevhunter
Some of those Tapers get a bit damaged at the ends. It pays to spend a Bit of time with a scraper or fine rat tail file to carefully dress any damage before Matching with the New Part. It's all unsprung . Nev
Posted: Sat May 16, 2026 8:53 am
by tony.barnett
All useful info chaps. I have got some steel to make some brackets.
