Top end troubles
Pictures (or stories) of hideous injuries sustained by your Ariel
Re: Top end troubles
Post by will_curry »
Simon,
That inlet valve looks to me as if it's being held off its seat.
I wouldn't expect to see anywhere near as much soot and lacquer on the
underside of the valve head or the valve stem.
will_curry wrote: Mon May 15, 2023 9:57 pm Simon,
I'm sorry - my mistake, that's the exhaust valve.
Post text now corrected! That's what two beers and a huge plate of curry does for you...
Simon,
That makes more sense.
I've got to ask: what sort of curry?
Will Curry cause you problems? Nev
Chicken, and it was delicious. Problems? Does falling asleep on the couch count?
What can we do about a loose cylinder head guide bore folks? My inlet is a little loose in the W/NG (iron head obviously). Do I need to make an oversized guide or are they available?
Paul Gasson
Post by Paul Gasson »
Simon, I had a problem with my iron 350cc head and could not find an intentionally made oversize guide so I ended up buying a few standard items from various sources and selected the most appropriate to get the correct fit. There was only a few thou in it for me so if more you may need to get one made. Make sure the hole in the head is round and bore or hone it if necessary before measuring as mine was slightly oval.
I wondered why Ariel didn’t offer oversize guides when other makers had a range of sizes available, it seems to be a problem affecting Ariel alloy and to some extent iron heads.
1935 RH, 1950 NH
Pete.Silson
Post by Pete.Silson »
Simon
If the guide is only a few thou loose then the simplest solution is to nickel plate a new guide. I did this on an iron head BSA way back when and the guides stayed put ever after.
I also remember my mate at work who simply knurled a guide and refitted it. Whether that worked for long I don't know.
Pete
Pete.Silson wrote: Fri May 19, 2023 3:01 pm
Simon
Pete
Ah yes, good idea. I have a batch of plating to do this summer.
Will it do any harm if I leave it for a while longer?
Post by Simon.Gardiner »
simon.holyfield wrote: Fri May 19, 2023 3:42 pm ''''Will it do any harm if I leave it for a while longer?
Simes, exactly how loose is it (eg wobbly, finger-tight) ?
