Page 2 of 2
Re: clutch tabs - ask a stupid question.....
Posted: Wed Apr 08, 2026 11:02 pm
by Roger Gwynn
I do them up tight without a lockwasher, I can't remember when I had one come loose. Draganfly make them in 3 sections following a tip in Cheval about 40 years ago we also make the screws without a slot so that a socket has to be used, thus increasing the chance that the fitter will do them up tight.
Posted: Thu Apr 09, 2026 7:29 am
by nevhunter
The bolt has to be Made correctly with a Plain section where the Shear takes Place Worn Bolts and Ovalised holes should be rectified No
oil around and probably Loctite in . Nev
Posted: Thu Apr 09, 2026 9:07 am
by Roger Gwynn
Yup, bolt not set screw as original
Posted: Thu Apr 09, 2026 7:46 pm
by Duncan J Robertson
Blue Locktite (medium strength) works, But I like a tab washer, easy to use and they do what is asked of them.
