sq4 alternator
RenzoLuigi.b
Re: sq4 alternator
Post by RenzoLuigi.b »
I have some sketches, if you give me an email address I'll send them to you
Renzo
Re: sq4 alternator
RenzoLuigi.b wrote: Sun Feb 22, 2026 5:32 pm I have some sketches, if you give me an email address I'll send them to you
Renzo
I'm sure many of us would like to see how you did it. Perhaps post the pictures here?
RenzoLuigi.b
Re: sq4 alternator
Here are two more photos; I can't do more without dismantling the pieces. I've also attached a rough diagram.
If you give me some time, I can make you some working drawings.
C_Users_Renzo_Desktop_disegni dell_parti moto Model (1).pdf
(58.72 KiB) Downloaded 51 times
ken-drink
Re: sq4 alternator
Post by ken-drink »
looks very interesting, look forward to seeing the drawings
Re: sq4 alternator
When I made my conversion I decided to do away with the distributer, which meant that I did not have to modify the crankcase. I extended the shaft to the left of the alternator and mounted a Boyer ignition unit that would fail after a few hundred miles, since replaced with a Wassels unit. Bloody awkward to fit, but the standard dynamo isn't easy without stripping the whole bike. I have 4 drawings including a plate for mounting the ignition system. There is an adapter - alternator to engine, a new back and front plate and ignition housing. Available as DXF, SKF or .doc files if anyone is interested. Bennett's version retains the distributer so involves less palaver.
ken-drink
Re: sq4 alternator
Post by ken-drink »
Be interesting to see the drawing
Re: sq4 alternator
Doc6.docx
Adapter plate
(26.14 KiB) Downloaded 47 times
Doc6.pdf
(208.21 KiB) Downloaded 69 times
RenzoLuigi.b
Re: sq4 alternator
Here are the working drawings for installing the alternator on an Ariel MK1.
I can provide the DWG drawings if needed.
(98.95 KiB) Downloaded 70 times
Re: sq4 alternator
A better engineered job than mine! Very nice
RenzoLuigi.b
Re: sq4 alternator
Thanks Roger, I'm glad a technician like you appreciates my work.
Renzo
