sq4 alternator
RenzoLuigi.b
Re: sq4 alternator
I have some sketches, if you give me an email address I'll send them to you
Renzo
Renzo
Re: sq4 alternator
I'm sure many of us would like to see how you did it. Perhaps post the pictures here?RenzoLuigi.b wrote: Sun Feb 22, 2026 5:32 pm I have some sketches, if you give me an email address I'll send them to you
Renzo
RenzoLuigi.b
Re: sq4 alternator
Here are two more photos; I can't do more without dismantling the pieces. I've also attached a rough diagram.
If you give me some time, I can make you some working drawings.
- Attachments
- C_Users_Renzo_Desktop_disegni dell_parti moto Model (1).pdf
- (58.72 KiB) Downloaded 51 times
Re: sq4 alternator
looks very interesting, look forward to seeing the drawings
Re: sq4 alternator
When I made my conversion I decided to do away with the distributer, which meant that I did not have to modify the crankcase. I extended the shaft to the left of the alternator and mounted a Boyer ignition unit that would fail after a few hundred miles, since replaced with a Wassels unit. Bloody awkward to fit, but the standard dynamo isn't easy without stripping the whole bike. I have 4 drawings including a plate for mounting the ignition system. There is an adapter - alternator to engine, a new back and front plate and ignition housing. Available as DXF, SKF or .doc files if anyone is interested. Bennett's version retains the distributer so involves less palaver.
Re: sq4 alternator
Be interesting to see the drawing
Re: sq4 alternator
- Attachments
- Doc6.pdf
- (208.21 KiB) Downloaded 69 times
RenzoLuigi.b
Re: sq4 alternator
Here are the working drawings for installing the alternator on an Ariel MK1.
I can provide the DWG drawings if needed.
- Attachments
- (98.95 KiB) Downloaded 70 times
Re: sq4 alternator
A better engineered job than mine! Very nice
RenzoLuigi.b
Re: sq4 alternator
Thanks Roger, I'm glad a technician like you appreciates my work.
Renzo
Renzo
