1927 ariel burman q clutch
rodney.mccue
hi checking the clutch on a burman q does anyone know if the large nut that holds the centre of the clutch to the basket
does it have a washer next to the 1/4 x 1/4 rollers before the large locking nut or not ( this is the large circular nut at the back )
thanks in advance
rod
thanks in advance
rod
- Karol Burger
Re: 1927 ariel burman q clutch
look at the photos in this ad. The product is currently sold out, but you can see how it works from the photo
https://www.arielklub.sk/inzerat-2432-2 ... jky-Burman
tony.barnett
Just one thing - they are not 1/4 x 1/4 rollers (as I found out when sorting my 1928 clutch). They are 1/4 x I think...15/64 (definitely an odd number).
KOBI
Velocette MAC, KSS Mk1
Tony, you are correct 1/4 x 15/64 so that the rollers don't bind in the 1/4" gap
Wot?
15/64"! I have to check that now..
On other Burman clutches AJS Matchless, Panther etc. the gap is made to fit the standard 1/4 rollers with sufficient clearance. Nev
Nev, I am surprised if what you say is correct as it is standard on all clutches that I am familiar with including BSA and Triumph clutches to use the 15/64 rollers including the Ariel 2 strokes.
Roger IF they make that size it must be for a reason so do what works, If you run out of end clearance you'll wear flats on the rollers. AJS/Matchless two in the last few years and my 1930 model G. Must finish that one day. Mechanicals are done. All part of the challenge. Nev
The rollers on my 1928 clutch have a small recess at one end that i know not the reason for.
Part of the manufacturing process, I would suggest. Some are slightly domed too. Nev
