Square four overhaul/valve guide seals etc.
Re: Square four overhaul/valve guide seals etc.
Post by JohnnyBeckett »
hi i would not fit seals it need to get oil in the valve guides to lube them and slow the wear down
mike.loehr
Post by mike.loehr »
Modern definition of Valve stem seals from all manufactures regarding todays high performance engines.
Low friction and long term emissions control
Valve stem seals provide a defined metering rate of oil to the valve stem interface of internal combustion engines to lubricate the valve guide and minimize engine emissions. They are available for diesel and gasoline engines with and without boosting.Point of interest is a metered amount of oil to lubricate valve stems.
Mike Loehr
allan.walker
Post by allan.walker »
Johnny's comment echoes my question about the use of seals, but Mike's post has answered it precisely. Thank you both.
The seals are designed to allow some oil to pass to provide lubrication, which sounds right.
