VH 1956 44-tooth primary chain sprocket
Philmynd
Post by Philmynd »
Wanted:
44-tooth primary chain sprocket for VH 1956. France, Acknowledgments
Philmynd
Re: VH 1956 44-tooth primary chain sprocket
Post by Philmynd »
Hi Members,
I found the 3380-36 sprocket at Draganfly, but can you tell me where to find the center of this sprocket: 3380-05
Thanks
Post by JohnnyBeckett »
hi you may get one from Greff brown at the AOMCC gearbox spares or try john budgen he has a lot of spares
Philmynd wrote: Thu Jul 28, 2022 6:35 pm ....but can you tell me where to find the center of this sprocket: 3380-05
Phil:
For the Drags sprocket you would usually re-use the centre from your old sprocket (or a spare old sprocket).
Philmynd
Post by Philmynd »
It is really marked, the surface treatment has disappeared in places :(
Remanufacturing seems obligatory.
Philippe
It looks good to me. If it is the centre where the bearings run that is of concern. It is really hard and not likely to wear as the bearing only operates when the clutch is operated. Any vertical movement in the bearing is usually cured by a new set of rollers.
Philmynd
Post by Philmynd »
Trouvé en Grece !!
Philmynd
Post by Philmynd »
Toutes les pièces sont arrivées, remontage et essais
hi when i rebuilt my gearbox and clutch i just fitted new rollers in the basket that i got from the clubs gearbox spares :D i have never needed to change the basket
ariel.andersen
Post by ariel.andersen »
Hello.
I got this NEW OLD STOCK for sale.
If interest you are welcome to send a PM to:
<ariel.andersen@godmail.dk>
Jorgen
