Wanted: New engine parts for 1956 Square Four Ariel
LBowen
Post by LBowen »
Hi all,
Looking for the following parts for 1956 Square Four Ariel -
Right hand main bushes STD
Big ends .010 over size
STD rings
New oil pump
Inlet valves
Exhaust valves
Timing chain
4 Conrods (I hear they are making better new ones)
Thanks
Les Bowen
keith wainwright
Re: Wanted: New engine parts for 1956 Square Four Ariel
Post by keith wainwright »
Save your money on new rods fit a Morgo pump together with a screw on filter and use modern multigrade oil 20/40. Clean out the sludge traps on the crankshafts. Good to go on the bottom end.
keith wainwright
The other items that you require can be obtained from Draganfly.
LBowen
Post by LBowen »
Thanks Keith
