Fake HS?
Bob.Murphy
Re: Fake HS?
Post by Bob.Murphy »
Are there any non-remote areas in Finland :? .
Its all remote from here ;) .
Maybe not remote enough from Russia . . .
adrie.degraaff
Re: Fake HS?
Post by adrie.degraaff »
You will be much happier with VH and HT.
I will send you a PM.
seppo.seppanen
Re: Fake HS?
Post by seppo.seppanen »
Yes. Plenty of empty areas with no-one even close. Luckily staying on west coast and not next to the eastern border...
1953 Square Four MK II
adrie.degraaff
Re: Fake HS?
HS has a very small petroltank and uses much more petrol.
Re: Fake HS?
The HSMkI cam was a cast one, all other cams including the HS MkIII cam (which is hollow) are made from steel.
If it is possible / allowed to take the timing cover away + oil pump you could / should be able to see if it has a cast or a steel camshaft.
