Problem lapping head to barrel on a '54 VH500
Re: Problem lapping head to barrel on a '54 VH500
As long as you have a gap between the head and the barrel. I had 0.016".
You could blue the spigot, place head on square, and lift off square, just to check the fit to the head,
As somebody else mentioned, very carefully clean the head as the grit in the paste will get embedded in the softer alloy.
(Grinding paste designed for hard valves and hard seats really, where its unlikely to become embedded)
Head bolts torqued to 20 lb/sq in.
dennis.t
Julian,
Thanks for the tip. I will check the fit with engineer's blue. And thanks for the torque value.
Dennis
Dennis
1955 VH500 alloy head
1955 NH350 alloy head
That's not a torque figure. It's a pressure. Do you mean 20 ft/lbs?
Yes. Slip of the pen...
Been testing too many valves.
Should read ft/lbs
Should read ft/lbs
- keith.mettam
Hi Dennis,
A 1958 Ariel factory document gives 25 ft lbs torque for the head bolts.
All the best,
Keith.
All the best,
Keith.
dennis.t
Keith, thank you for the clarification.
Dennis
Dennis
The head sits on the spigot not the barrel. This provides a high contact pressure to provide a gas tight seal. But check with engineers blue that there is full contact between head recess and spigot. Then use fine paste if necessary.
dennis.t
Will do thanks,
Dennis
Dennis
