wanted
wanted
well i have got the bike sorted i didnt want to build it as a concourse bike just one that has the ageing look that i think it deserves and it is running and sounding great fixed the gearbox problem (clutch arm was round the wrong way )the little bump bit on it was not faceing the clutch had to put another 5/16 ball in that now makes the clutch rod 10 and 5/16 any ideas about that? it took an age to kick the oil through even with no plug in, my leg felt it with that done i put my run up tank on and guess what IT STARTED FIRST KICK not bad from a couple of boxes of parts that have sat in a leaky garage for the last 25 years with the clean up and newley built wheels i cant wait for the trial run around the block as they say but before i can do that i need the tank centre fixing kit and the 4 rubbers that the tank sits on i will look in the spares dept. if you have them also how the heck do you get those rubbers on the tank regards Jim
Re: wanted
I wrote a bit about it here. My rubbers came from Jeff Hunter:
https://ariel-square-four.blogspot.com/ ... k.html?m=0
