- Steven.Carter
I'm thinking that in my case as I had the engine plates powder coated, the paint probably turned to dust under the nuts and washers.
Steve, on Agnes, does the ESA sit behind the sprocket or is there no ESA ?
johnnelson
Paul great memories of rail motors on the NYMR, never realised they were VP designed engines no wonder we could make them fly
- Steven.Carter
I'll take a photo later,Vincent.vanGinneke wrote:Steve, on Agnes, does the ESA sit behind the sprocket or is there no ESA ?
I'm off to the seaside today. Eastbourne leisure centre. Right next to the beech.
Let us have a picture of you on that octopus !
- Steven.Carter
Saw that on the way in
Got a picture of a tank.
- Steven.Carter
Will this help?Steven.Carter wrote:I'll take a photo later,Vincent.vanGinneke wrote:Steve, on Agnes, does the ESA sit behind the sprocket or is there no ESA ?
Ah, yes, I see. the ESA is behind the sprocket.
And that oil-mist- line goes to the inlet valve I presume.
- Steven.Carter
It was Adrie's idea.
The pipe comes up and goes through a tee. Then blows into both inlet and exhaust valves
