Chaincase E9/6436
charles.bulloch
Chaincase E9/6436
Post by charles.bulloch »
Hi all.
What machine does the above inner chaincase fit?
Charlie
BobWard
Re: Chaincase E9/6436
Post by BobWard »
1954 - 58 swinging arm singles NH VH VB. Bob
1958 Huntmaster
1957 VH 500
1960 FB Cruiser 84
Post by JohnnyBeckett »
hi, my 1954 NH 350 inner chaincase number is E9/3000 and i think my 1956 NH inner chaincase number is E9/3436 because i was working out witch case fitted which year bike last year wen in lock down and it workout to to be E9/3000 for my 1954 NH 350 but i will get someone to go to the workshop tomorrow and have a look at the numbers :?: because that is the numbers i put in my book that i have at home :?: and if the numbers are wrong i will put up a new post
BobWard
Post by BobWard »
Johnny B you are correct 56 - 58, can I blame the Oxford AstraZeneca jab six weeks after the real COVID recovery giving me all the same symptoms back for two days.
1958 Huntmaster
1957 VH 500
1960 FB Cruiser 84
hi Bob that will take you a lot of time to get yourself right again after that , and i wish you well soon, and i thought i may have got it wrong because my Brain has gone after having a big life changing op before the new year and being put in lock down again since last September and i hope i am able by the end may to start doing a bit ,if i am let-out of lock down :)
charles.bulloch
Thanks for the replies, Bob and Johnny. The number is actually E9/3436, so it is for a 56 on single.
Charlie
hi Charlie its is because the 56 on gearbox has got a longer main shaft and the gearbox drive sprocket spacer is thicker so the case sits out a bit more
