Kh crankcases
d.mulcahy
Kh crankcases
Post by d.mulcahy »
I wonder if any members can help the drive side of my crankcase had some bad cracks in it so had it welded and die tested. The drive side bearing is now to tight to refit so not sure correct size to machine the casing to does anyone the the correct dimension it should be machined too? TiA.
