Rod bolts
BrianReynolds
Rod bolts
Greetings and Happy new year from Manitoba in winter. I am about to assemble my Mk2 Square 4 engine. I have reconditioned the original rods but was unable to find a full set of new bolts. Does anyone have the exact length of the original bolts? I want to measure and check the originals have not stretched. The nominal length appears to be 2.250” with some variation. Unless of course someone has 6 new bolts stashed that they are willing to part with? Any assistance appreciated. Thanks.
john.whiting
Re: Rod bolts
I would suggest a careful visual inspection for stretched /deformed threads,and if they look OK ,the get the bolts magnafluxed,....be a good idea to have the rods crack tested too....Im thinking non magnetic alloy material can be crack tested by running a current thru ,and testing for discontinuities in the magnetic field ,similar to magnetic materials like the rod bolts......If not ,then crack testing will be penetrant & dye check.....better than nothing.
BrianReynolds
Re: Rod bolts
Thanks, I had already crack checked ( i own a commercial machine shop so no problem to magnaflux the rods and bolts) however there is a variation of up to 0.010” in the lengths of the 8 bolts, the longest being the 2 new bolts, so nothing to use as a comparison. I am at the point where it all looks good, so I think I am comfortable to assemble.
- john.bebb
Re: Rod bolts
Hi Brian - Happy New Year to you also. Suggest that Bruce Longman (Club Spares) may be able to supply you with new set of bolts...
Cheers, John
Cheers, John
Users browsing this forum: No registered users and 11 guests
