Mounting direction with Omega pistons
r.emontsgast
Post by r.emontsgast »
Hello,
Do you have to pay attention to an mounting direction with the Omega pistons ?
I did not find a corresponding mark on it.
Best regards,
dave.owen
Re: Mounting direction with Omega pistons
Post by dave.owen »
Best ask Peter Kemp, if that's where you got it from
Dave
r.emontsgast
I asked Peter, here is his answer:
No direction, so either way is good.
Make sure the new bore is good and correct so the datumn is off the underside of the flange, some try and come off the top and Opsss it does not work. Alsofit the piston rings the correct way as easy to get mixed up.
