GB box clutch
Brian Andrews 2180
GB box clutch
Post by Brian Andrews 2180 »
Can anyone tell me the free length of the five clutch springs please.
Re: GB box clutch
Post by will_curry »
i measured 3 sets of clutch springs a while ago. All were more-or-less 42mm long
and wound with 7 turns. One set had a wire of just over 2mm thickness
and the other two had a wire thickness of around 1.6mm.
Post war at least Ariel Burman clutches used two different strengths of
clutch spring, one for cork clutches and the other, stronger, for 'fabric'
clutches. Draganfly springs seem to be based on the stronger springs
and to my mind are unnecessarily strong for a cork clutch.
Hope this helps.
Re: GB box clutch
Post by JohnnyBeckett »
hi Will do you know what the clubs gearbox spares clutch springs are based on :?: i have fitted a set on my NH and its got a cork clutch
Re: GB box clutch
Sorry Johnny,
I don't know what the club springs are based on. I'm fortunate in that many years ago when
the factory closed I acquired the stock from a local dealer which has kept me going for
the last 50+ years. One of the many nice things about Ariels is that they don't wear out as
quickly as some contemporaries, at least when carefully used - trials, scrambles, the odd grass-track
and lots of pub-crawls, that kind of thing.
