LuisPaz
Posts: 320 Joined: Fri Jan 19, 2018 12:59 am
Post
by LuisPaz » Thu Feb 20, 2020 2:55 am
Once again I request your help with measures to reproduce the clip. Any drawing? Hole size? Nut and bolt?
Lenght between both clips?
Thanks in advance!
Luis, from Argentina
1944 Ariel WNG
john.nash
Posts: 1196 Joined: Mon Feb 14, 2011 4:46 pm
Post
by john.nash » Fri Feb 21, 2020 12:42 pm
John Nash
AOMCC No.4119
alan.moore
Posts: 1461 Joined: Sat Jul 19, 2014 1:29 pm
Post
by alan.moore » Fri Feb 21, 2020 7:16 pm
Mariano....just a tip, sometimes if the toolboxes are not WNG originals they don't line up correctly with the original brackets fitted. Try making a couple of brackets out of thin scrap aluminium first to get the alignment correct then make out of steel. Don't forget the L shaped bracket from the rear of the top box to the mudguard stay (6561-41) and the reinforcing metal strips 6565-35 that fit inside the toolboxes under the bracket securing nuts.
I will send you the rear mudguard measurements this weekend
Alan
LuisPaz
Post
by LuisPaz » Sat Feb 22, 2020 2:21 am
John , Alan thank you very much for your reply!
Today I made the clips according the WNG pics found on Google.
Seems to be I have a good eyes ....
1944 Ariel WNG
LuisPaz
Post
by LuisPaz » Sun Feb 23, 2020 2:07 pm
1944 Ariel WNG
Posts: 2665 Joined: Sat Jul 07, 2018 5:39 pm
Post
by JohnnyBeckett » Sun Feb 23, 2020 10:40 pm
HI Another very good job you have made again
alan.moore
Post
by alan.moore » Sun Feb 23, 2020 11:36 pm
Nice job
LuisPaz
Post
by LuisPaz » Tue Feb 25, 2020 1:31 am
Thank you Alan!
Today reinforce clips with more welding!
1944 Ariel WNG
