1961 Arrow where do these pats go?
BernieP
Post by BernieP »
I have just fitted a new primary chain and tensioner and now have two small parts left, are they blanking plugs for the contact breaker-ignition timing holes?
If not where do they go?
Many thanks for looking.
Bernie
roy.craddock
Re: 1961 Arrow where do these pats go?
Post by roy.craddock »
Hi Bernie, I don’t recognise those parts from anything in the primary chain case area, best way forward is to look up on Draganfly website, on their parts listings, they show drawings etc of parts with part no etc, I hope this helps you ,Regards Roy
BernieP
Post by BernieP »
That was the first place I went, must have spent 30 mins or so trying to find them but to no avail.
Thanks for the suggestion
Bernie
tstewart
Post by tstewart »
I am interested as I have not seen these parts and I am sure I have not fitted anything that looks like that. But I have missed things before.
bob.keevil
Post by bob.keevil »
Hi Bernie
Why did you replace the chain tensioner ? was the chain broken as they look a bit chain links to me.
Cheers Bob K
BernieP
Post by BernieP »
I could not adjust the primary chain, so I took the cover of and found the plastic adjuster was broke, while I had it striped down I thought it was a good time to change the chain and tensioner. the chain was not broken but comparing it to the new one it was longer.
They are larger chain links and made of brass and 4.40mm at the narrowest and 9.40mm at the widest.
I can remember taking the two items off, I seem to think they were under a gasket but not sure.
Thanks for all the help and advice.
Bernie
