david.anderson wrote:Paul
It is worth considering upgrading the original rocker box. As the original rocker box was flawed in design and resulted in oil leaks, the South Australian Police Force mechanics designed a leak free rocker box which was then used on all police bikes. The Australian Ariel Register commissioned a pattern to produce the police force upgrade and has produced a couple of batches of the rocker boxes. Unmachined boxes are available at $225au. (about half that in GB pounds)
http://www.australian-ariel-register.com/default.html
Thank you David...and a couple of us have been in touch with Greg and Col Hill and our boxes are being cast, machined and zinc plated as I type. Very impressed with the photos and, even more so, by the very reasonable cost.
More progress on the rest of the engine as I got my cranks back from the grinders yesterday. Crank pins ground to -10 thou and the main journals made circular (1.234"); shells ordered from Bruce.
With cranks back, I can start making the timing side bushes from leaded bronze (SAE660). Quite a lot of discussion on the FB Ariel Group about the pros and cons of leaded bronze versus white metalled bushes, but the consensus seems to be that modern oils + cartridge oil filter means leaded bronze is better. Bennett Longman (Bruce's son) posted some rather nasty photos of failed white metal bushes after 25,000 miles from his SQ4, and if Bruce/Bennett are using leaded bronze, who am I to argue.
I'll be reaming my new bushes in-situ so have made the following to support the end of the HSS adjustable reamer by indexing it with the outer race of the new roller bearing in the far side. Ali block in far shell held in with a light interference fit and the brass bar is a sliding fit through it. The brass bar supports the end of the reamer. This is the plan anyway....hope it works.
