Magneto sparks at points
Bram
Post by Bram »
Hello to all hope you’ve had a good X-mas. I have tried to find in the forum my problem but could’nt find it
We talk about a magneto for a NG/NH. If i turn the magneto with my hand i have a spark over the breaker points. Sometimes over the igniter plug. If i connect the magneto to the engine and kick it there is no spark at all???? Now i believe that making an extra ground from the magneto to the engine eill help, but it is still a strange thing that it spsrks over the points. I have put new ground brush and igniter brush
Any one an idea?
AndrewLeslie
Re: Magneto sparks at points
Post by AndrewLeslie »
Hi Bram,
I think large sparks at points means the condenser is breaking down.
Eero.Korhonen
Post by Eero.Korhonen »
Yes it is, unfortunately. You need to disassemble the magneto and change the condenser.
I usually put in modern ones and fill space with araldite or something similar.
Br, Eero
Bram
Post by Bram »
Hi Eero
Can you give me some info about that condensor? Where to put it / connect it and which type?
Thanks Bram
Bram
Post by Bram »
Gentleman, i am talking about a magdyno. As far as i can see on pictures there is no condensator
chris.shearwood
Post by chris.shearwood »
Hi Bram,
There is a condenser inside the magneto. Check out this web site for information with regards to your options:
http://www.brightsparkmagnetos.com/cond ... /index.htm
Regards, Chris
1946 4G and 1951 VH
ian.scott
Post by ian.scott »
I had one of these Brighspark condensors fitted some couple of years ago and the mag has performed faultlessly ever since.
Ian
Bram
Post by Bram »
Gentleman
Thanks for your redonses and the link. I will take it off and check keep you posted but be pationed. I have a lot of things going on
Wish you a happy new year
