W/NG Lucas switch
LuisPaz
W/NG Lucas switch
Post by LuisPaz »
Months ago I bought this switch in the USA to install in my 1944 WNG.
I had to wait for a friend who made a trip to Miami, to be able to bring him to my country.
Could it be WD by the "T" test?
Thanks in advance!
Luis, from Argentina
1944 Ariel WNG
Re: W/NG Lucas switch
Definitely military. The T position is 'Tail' in this instance, which is for convoy use - it connects the tail light terminal to the battery. You get tail light only - no pilot or headlamp.
As I understand it ,that switch does most of them except the 1944 OTA, which has a distinct position with TEST shown. the switching is different the way it works also. I've only seen one like that. John Nash probably has the clues on this Some later ones have the switch under the seat. and the headlamp position is blanked off. Nev
LuisPaz
Post by LuisPaz »
Thank you Simon!
Nev, i think the switch need my wng is very hard to find...
1944 Ariel WNG
That's the later one. Nev
admin
Post by admin »
as Nev said, the underseat switch is coupled with a "blanked off" headlamp switch panel (featuring no ammeter) on later machines.
I swapped such a headlamp panel and have seen a couple of others.
I have never seen an underseat switch however ... despite the fact they were fitted to other manufacturers bikes and the production run was likely tens and tens of thousands ...
and this is how that looks.
But I am not sure about that small black switch
LuisPaz
Post by LuisPaz »
Hi Vincent
These switch seems to be the push operated switch.. :roll:
1944 Ariel WNG
This under seat switch position -next to the battery- is to save on wiring material to the headlamp.
Although there was more material to gain if Lucas would have left the headlamp shell blank with no aperture and no separate dash.
But Lucas was in darkness as The Prince in those long ago dark days in a different world... ;)
alan.moore
Post by alan.moore »
See this previous post, may answer some questions
http://forum.arielownersmcc.com/viewt ... =47&t=5472
Alan
