NH/NG piston wanted
NH/NG piston wanted
Wish to get a .040 or .060 piston for an NH/NG 350, with either 7,5:1 or 8,0:1 CR. A used one is also of interest, as long as it's not damaged or totally worn out.
Re: NH/NG piston wanted
Hello Tbarnes , one on Ebay from Egypt with contact address in Birmingham .
https://www.ebay.co.uk/itm/ARIEL-OHV-PI ... rk:11:pf:0
Hi, thank you for the tip, but I'm afraid it's a standard piston with 6,2:1 CR, beeing a Hepolite 11210.
What I need is either a Hepolite 4469 (7,5:1 with three compression rings, no oil ring),
10431 (7,5:1 with two compression rings and one oil ring)
or 11548 (8:1 with two compression rings and one oil ring).
I had +0.020, +0.040 and +0.060 4469 pistons brand new in their boxes for many years. When I converted the Red Hunter back to 500cc about 5 years ago I sold off all my 350 bits. I found it extraordinarily difficult to sell the pistons which eventually went for little more than a pittance on Ebay.
Wonder where they are now...
People "wanted " the more muscular") OHV's. As a callow (and poor ) youth I rode a 1936 Ariel RH 350 a 1947 ZA7 BSA 500 twin and then a 1948 Royal Enfield bullet with a swing arm frame. I only "pillioned" one bike, the Enfield and for a time it was my only transport to work, Uni at night ( the other side of Sydney and home (Newcastle) at the weekends.. The only mods to the Enfield was a roller big end conversion I fitted and some port reshaping.. I never felt the bike was inadequate with the power and the roller bearing lasted longer than the original floating whitemetal one fitted.. I did thrash it but liked it generally except the frame flexes and the gearbox was an Albion that stuck in two gears at once, once. Nev
tony.barnett
Have you tried Single Spares?
KOBI
Velocette MAC, KSS Mk1
Brian Andrews 2180
Hi Tony hope all is well in Swindonia can you give us a call re piston 01843 293370 regards Badger.
Found it, Draganfly had a kit with a std 8,5:1 piston and a cylinder liner. So got another cylinder today, and will get it lined and fitted with the 8,5:1 piston. Maybe a tad high CR, so I should fit a shim under the cylinder, or mill the crown little bit...?
