Float sticking
john W
Float sticking
Post by john W »
Hi has anyone had problems with the nylon float needle sticking and causing fuel starvation have taken one out of another carburettor but
still having the same problem
charles.bulloch
Re: Float sticking
Post by charles.bulloch »
Me too. Very annoying
Charlie
AndyEames
Re: Float sticking
Post by AndyEames »
Has it got a rubber tip on it ? I have heard of the rubber swelling and sticking. I think you can get a Viton tipped needle that ( hopefully ) cures this.
Andy
john W
Re: Float sticking
Post by john W »
Thanks for you help again Andy (did you get the second message on Sunday re the other bike) it hasn't got a rubber tip on and it seems to be an
intermittent fault do you know where I can get a Viton tipped one from
John
AndyEames
Re: Float sticking
Post by AndyEames »
Hi John. Yes ,got the 2nd message. We will have to meet up and have a natter some time. I will be at Curborough sprint (Fradley) the weekend of the 6th (saturday). If you go ,look for a silver Honda V4 400, number 566. Burlen should have the needles.Just checked. They have a float and needle kit ,£19. Just put Burlen into google.
Andy
iansoady
Re: Float sticking
Post by iansoady »
I always throw those nylon needles away as far as possible. The brass ones with the Viton tips work much better.
Available direct from Amal or (my favourite) Hitchcocks.
Ian
1952 Norton ES2
1982 Moto Guzzi V50
john W
Re: Float sticking
Post by john W »
Thankyou again Andy for your help but we are doing something else on 6th and yes we will have to meet for a chat sometime also thanks for the info Ian
regards
John
bob.keevil
Re: Float sticking
Post by bob.keevil »
Hi John
Are you sure it is the needle that,s sticking as I had the opposite happen, turning on the fuel the float chamber flooded only to find the shaft that the float moves on had a black line on it and cleaning the shaft the float moved freely and no more flooding. Just a thought.
Cheers Bob K
iansoady
Re: Float sticking
Post by iansoady »
Another point - it's easy to mislay the little spacer that goes on the float spindle after the float is fitted. This lets the float bind on the cover.
I also once had a problem with a Triumph unit twin where the mould line on the float was catching on the casing. Probably a defective pattern part, but a few strokes of a file sorted it out.
Ian
1952 Norton ES2
1982 Moto Guzzi V50
