Arrow 6v to 12v
General electrical problems
A.clarke
Arrow 6v to 12v
Post by A.clarke »
Hi all
Does anyone know the battery number you need if I change from 6 volt to 12 volt on my ariel arrow, and advice on other parts that may need replacing.
Thanks
David.Smewing
Re: Arrow 6v to 12v
Post by David.Smewing »
I converted my arrow to 12v Pazon ignition, and used the following battery, rotor, stator and regulator. The stator is very slightly bigger than the original Lucas, so a bit of turning/ easing to get it to fit. The higher power of this stator allows a halogen headlight without draining the battery.
regards
Dave Smewing
http://www.allbatteries.co.uk/motorcycl ... ot027.html
https://www.vmccshop.net/rotor-wassell
https://www.vmccshop.net/stator-wassell-1
https://www.vmccshop.net/solid-state-re ... or-wassell
A.clarke
Re: Arrow 6v to 12v
Post by A.clarke »
Thanks Dave
My arrow above half throttle seems to miss and spit back so I think it's loosing it's spark or it is irratic at high rev's. My Pazon is for 6 or 12 volt but I assume I will have to use 2 - 6 volt coils instead of the 3 volt supplied.
Alan
David.Smewing
Re: Arrow 6v to 12v
Alan
I used the Pazon True-Fire Ariel Arrow/Leader (12 Volt) which allowed me to use the old 6v coils, so I don't know about your system - sorry
regards
Dave
iansoady
Re: Arrow 6v to 12v
Post by iansoady »
Does that system use an idle spark (ie firing both coils at the same time)?
Ian
1952 Norton ES2
1982 Moto Guzzi V50
A.clarke
Re: Arrow 6v to 12v
Post by A.clarke »
Hi Ian
Yes it has the waste spark.
Alan
iansoady
Re: Arrow 6v to 12v
Post by iansoady »
Thanks. I'm building mine with points but may be looking at electronic later.
Ian
1952 Norton ES2
1982 Moto Guzzi V50
A.clarke
Re: Arrow 6v to 12v
Post by A.clarke »
I am just taking my Pazon electronic ignition off to rule that out as i have already had a fault with it.
Alan
