Vincent.vanGinneke wrote:Reg. this drawing; Looks like the levers for brake and clutch are the same.
You can see the slit for the wire on top in the right hand lever, making it a clutch lever.
If drawing is correct they used clutch levers for left and right.
same part number. so yes.
