1934 Red Hunter
alan.moore
Re: 1934 Red Hunter
Post by alan.moore »
Nick
Have a look through these previous topics regarding the valve guide oiling system / feeds:
http://forum.arielownersmcc.com/viewtopic.php?t=2477
http://forum.arielownersmcc.com/viewtopic.php?t=778
adrie.degraaff
Re: 1934 Red Hunter
Post by adrie.degraaff »
paul.jameson wrote:The frame appears to be 1936 or later but I can't be sure from what I can see.
The rearbrakelever-to-the-frame-lugg appears to be welded to the frame in a later stage, in that case it could be 1934.
There are Ariel heads with oilfeed to the exhaust guide to but it's useless without oilpressior, the inlet is sucking so that will lubricate.
Nick.Wilson
Re: 1934 Red Hunter
Post by Nick.Wilson »
Here are a few more pictures to give everyone a rough idea of what I'm dealing with.
Nick.Wilson
Re: 1934 Red Hunter
The frame number reads F2764. So that should be a '36 frame, apparently.
If any one notices anything that should not be, or should be done differently from what you can see in the pictures, could you please let me know?
Thanks to everyone for their help.
Nick.
adrie.degraaff
Re: 1934 Red Hunter
If there's an x before the F than it's 1937.
A picture of the oilfeed (left) side of the head would be nice, and the brake paddle to frame connection.
Nick.Wilson
Re: 1934 Red Hunter
These are the only pictures i have of that side currently. I will get more pictures later on when i get home.
Thanks Adrie.
Nick.
ian.scott
Re: 1934 Red Hunter
Post by ian.scott »
That would be a 1936 style frame as my 35 VH has frame F257 and is 36 on type frame .
Ian
Nick.Wilson
Re: 1934 Red Hunter
Here are a few more pictures of the left hand side.
ian.scott
Re: 1934 Red Hunter
Post by ian.scott »
That looks like a home made mounting for the brake pedal ,which is odd for that frame number F2764, as my October 35 VH with frame no F257 has the proper 36 mounting.
Ian
adrie.degraaff
Re: 1934 Red Hunter
ian.scott wrote:which is odd for that frame number F2764, as my October 35 VH with frame no F257 has the proper 36 mounting.
Unless it's a good factory brake mounting than the frame is 1936 and the crankcase 1934.
