ignition timing
keith.hodgenia
ignition timing
Does anybody out there know the formula for converting distance BTDC into degrees BTDC. Thanks. Keith.
- charles.bulloch
Re: ignition timing
Hi, Keith,
since x = rcos A + sqrt{l^2 - r^2sin^2 A} you can't get the angle in a simple manner. I once wrote a program in basic which got the angle by iteration, but probably I could not do it anymore. The program did it in ten steps. l is the con-rod length and r is half the stroke.
http://en.wikipedia.org/wiki/Piston_mot ... ght_angled
Charlie
Charlie
keith.hodgenia
John.Cheetham
Re: ignition timing
Keith, You could try this website
http://www.torqsoft.net/piston-position.html
As in any calculation you will require the length of the con rod between centres.
John C
John C
- PeterW
Re: ignition timing
My father used to irritate me. I always liked to set ignition timing by the book, he'd set it by trial & error. He'd set it, take it for a spin, advance it, see how it felt, was it pinking etc., repeat a few times and settle on whatever he felt ran best.
His argument was that although the manufacturers settings were best when new, by the time he bought whatever it was it was old and worn. tolerances had changed, compression might be lower, adv/retard springs might be weaker and petrol might burn faster/slower/hotter/cooler. I don't think I'll ever have his feel for mechanics but I still try setting it a degree or two either side of correct just to see where it runs best.
So here's two questions.
1. what matters with timing - the travel of the piston or the time it takes to do it?
2. does modern petrol burn faster or slower?
keith.hodgenia
Thanks John, that's just what I need. Peter, your Dad was right on the money, this bike is new to me so I am not too sure what" feels about right" is just yet. I took it for a spin today and it was running hot and pinking on the hills. So retard the ignition or richen the mixture or look at the none standard exhaust. Banbury is in 2 weeks so I need to sort it out. Many thanks Keith.
- charles.bulloch
Re: ignition timing
There was a question on this very subject in this years Advanced Higher Physics paper. Unfortunately nobody at the exam board has an Ariel because the question ignored the effect of the con-rod length. Because the crank and piston is actually a linked system. So the x = rcosA equation is not valid.
Getting out more in future
Charlie
Charlie
leon.mitchell
keith.hodgenia
Thanks to everyone for their input. I seem to be making progress. As I mentioned I had some doubts about the exhaust system and whether it produced enough back pressure. It has the "coffee tin" expansion chamber often seen in the twenties, with a very short tail pipe. Period drawings show a much longer tail pipe back to around the rear wheel spindle. I have lengthened it a bit and reduced its diameter. The engine now revs well, Hopefully a bit more tweaking to the timing and mixture will see it running in an acceptable manner. My obsession with the ignition timing has been more about repeatability than ultimate accuracy, with very little room above the engine, measuring the advance by degrees could be a lot easier.
- Bob.Murphy
Re:
Aaaagggh . . I can't stand the suspense . . . WHAT IS ITkeith.hodgenia wrote: This bike is new to me so I am not too sure what" feels about right" is just yet. I took it for a spin today and it was running hot and pinking on the hills. So retard the ignition or richen the mixture or look at the none standard exhaust. Banbury is in 2 weeks so I need to sort it out. Many thanks Keith.
Show us some pictures and put me out of my misery
Users browsing this forum: No registered users and 67 guests
