Ariel V twin Crank
rein.heerkens
Re: Ariel V twin Crank
Post by rein.heerkens »
Where can I find the engine number on an AKD v-twin?
leon.mitchell
Post by leon.mitchell »
I've been back into history and dug out my AKD file. Not too much relevant to Ariels, but I'll attach the pages that describe the V twin motor. It shows the odd flywheels and the double bearings of the chain drive motor nicely.
I also found the engine and frame numbers of the AKD twin I had: A5325 and 3328 (AKD, not Ariel, frame number). The engine and frame had the look that they had always been together, and the frame was definitely a 1914 model AKD. By the way, there was an earlier series of AKD engine numbers without the prefix "A"; I believe that the same numbers were used in both series. That is there might be an Abingdon engine with engine number 1032 and a different engine with engine number A1032.
In my file, I also found a note that a "1914" Ariel was mentioned in The Classic Motor Cycle in January 1990 with engine number A9664 and frame 7515.
Hope this helps.
Leon
1915 Abingdon page 21
1915 Abingdon page 20
1915 Abingdon page 19
1915 Abingdon page 18
1915 Abingdon page 17
leon.mitchell
And if you are really interested, a high resolution copy of page 20 so you can read the little numbers!
Leon
1915 Abingdon page 20 - high resolution
leon.mitchell
Rein,
The engine number on the Bonham's Ariel-AKD mentioned above is on a raised boss on the crank case, on the timing side near the bottom.
Leon
GuyH
Post by GuyH »
Hi Leon, These pages are a great help thanks very much. I have the parts lists but they don't show the detail that these diagrams do. I can see the different sized flywheels clearly in the AKD drawings.
I've also uploaded a photo of my engine number for Rein
1939 600 OHV 4F, 1956 MKII Square Four, a Healey, 1939 OH 250, 1939 OG 250 plus a couple of OG250 projects, 1920 Ariel V twin project and a variety of lesser makes
adrie.degraaff
Post by adrie.degraaff »
leon.mitchell wrote:In my file, I also found a note that a "1914" Ariel was mentioned in The Classic Motor Cycle in January 1990 with engine number A9664 and frame 7515.
And now there is a 1920-1921 Vtwin at Bonhams of wich the owner asked the club to date it, they want to sell it as 1915 becouse a pre Aug. 1915 will bring more money.
If the pre 1927 archive of the Ariel factory wasn't distroied than we would have missed all this fun, nothing to ask, nothing to find.
So I want to thank all and specialy Leon for helping out.
rein.heerkens
Thank you all for the info, mine has engine number A10469.
andyhughesflattankarielpre25
Post by andyhughesflattankarielpre25 »
Hello Rein,is your machine a belt drive or chain
rein.heerkens
It`s a belt drive.
john.mitchell
Post by john.mitchell »
I attach a photo of my AKD flywheels. Engine no A10032. I am sure it is 1921. Incidentally I always believed it a mismatched engine in the MAG type frame until i came across a 1921 catalogue picture.
John Mitchell
