Oil union gauze is broken
Dave.Barkshire
Post by Dave.Barkshire »
The oil union has a gauze which is brloken on one side (not the side shown in the photo!)
I've never been able to solder these things successfully either because the gauze is dirty or in this case the metal is too bulky. The split is right on the edge where it meets the union bolt so there is nothing to even stitch it to.
Does anyone know of any tricks? Maybe I need to look for another one?
PS it's for the 1930 model G
ArielTankPart 003.JPG (127.97 KiB) Viewed 3913 times
Ariel Red Hunter VH1 1938
BSA L27 1927
Velocette MSS 1939
AJS Model 20 1953
Ariel Golden Arrow 1962
Triumph Scrambler 900
AOMCC Member 3400
Steven.Carter
Re: Oil union gauze is broken
Post by Steven.Carter »
I fixed my tank tap gauze with this flux with electrical solder and a small blow torch, seems that the flux was strong enough to deal with it
Steve
chris.vredenbregt
Post by chris.vredenbregt »
Hello Dave use a good paintstripper to heat up, because the hot air of the stripper is clean and a flame always gives smoke and carbon because you burn something.
Good luck Chris
Jens.Beuße
Post by Jens.Beuße »
Hello Dave,
you can send it to me directly.
I can solder a new gauze on for you.
Cheers Jens
P.S. still owe you a lever do we meet
at the AGM?
Users browsing this forum: Google [Bot] and 3 guests
