4G which type spark plug
klaus gerhard
Post by klaus gerhard »
What type spark plugs are recommended?
My engine still uses the magneto for the moment and therefore I am looking for a resistor free spark plug.
In the old days Champion L7 seemed to be the correct type but of course they are no longer available. I found as a replacement NGK B7HS or Bosch W5AC. What do you recommend?
Any advice welcome.
Thanks
KLaus
Reg.Webster
Re: 4G which type spark plug
Post by Reg.Webster »
The Green Sparkplug Co are great, I first saw them at a steam rally, and asked about spark plugs. I had an idea that using a spark plug that helped dissipate heat in the front pots, and one that retains heat in the rear would decrease the chance of distortion and damage to the head. He said good idea, I know what you need, your not the first to suggest that.
So helpful I won't buy plugs anywhere else.
