I've set myself a little task for this winter - to sort out the various bits on my bikes which need plating.
I believe that post war, most fasteners used by Ariel were cadmium plated, and I'm planning on some dull zinc plating to tidy up these fasteners.
My first query is this. Both my FH and my MK1 appear to have plating on the heads of the wheel spindles (both ends). Were these chromed?
Which bits are plated? With what?
Re: Which bits are plated? With what?
oooh! tricky subject. My opinion is that up to around 1950 all fastenings were blacked unless they sat on a shiny bit like an engine casing in which case they were chromed or nickle prior to 1930. Nickle was often used as a protective finish as opposed to decorative, Lucas dynamo bodies for instance and I have seen it specified on the 4035-46/49 front wheel spindles. This would have been a dull, unpolished finish, not bright, like the chroming on Amal bits. The parts can be plated then dulled by peening in a bead blaster or peen before hand and tell the platers not to polish. Zinc plating can be made to look more like cadmium by the same process, it is the smoothness of the metal that produces a bright finish although there is a specific dull plating process for chrome and I think nickle. The North Americans liked a bit of chrome and the importers would sometimes add a bit of sparkle to help shift the bikes and don't forget that 'any part can be had in chrome buy adding a 'K' suffix to the part number' 6200-46K anyone?
Ooh! The 'k' is an interesting little knugget I hadn't heard before!
Thinking about your reference to 1950 - the engine bolts on my MK1 were blacked.
Also, the front wheel spindle on the FH is nickel plated. Would you expect that?
Another question - the link plates and bolts on an Anstey rear end. Mine are chromed, badly. Are they supposed to be cad plated?
Cadmium is very toxic to work with and Aviation replaced it with Zinc- nickel years ago.Plating tends to be thicker towards the ends of threads and that can be a disaster. Also Hydrogen embrittlement occurrs IF not treated soon after the Plating (or stripping) is done. Plating is Porous and needs care and attention especially near salt and other corrosives. A lot of people plate Parts that were Painted originally. Money wasted in my view. ,
Some parts are copper plated and worked on to get a better finish/. Don't do his on exhaust Pipes or it will Blister. A general rule is Nickel till 1930 where Chrome then took over, often over Nickel. Nickel on exhaust pipes will blue extensively. Nickel has a great Look but will need more attention than chrome. Headlamp reflectors are done with Silver Plate. Zinc is soft and Provides Galvanic Protection as well as Physical protection.
Black Japan (Ceramic) was used on some( Mainly car ) exhaust Manifolds on up Market Models. Some plating makes Soldering easier..Nev
klaus gerhard
I wonder if it is true, I heard that in the late 30ies a bike could be ordered in "Show" configuration. That would mean that many exposed bolts and e.g. the rear lifting handle were chrome plated.
Another question - do the two strokes still use cadmium for fasteners or had Ariel moved to zinc plating by then?
Zinc is Pretty soft and unattractive. I'd like it Plated inside a Petrol tank. Internal rust is a Problem with old bike tanks. For Matt black Nuts etc Get them Very Clean spray them with High temp Matt Black and stove them after they appear dry. 180 c for 1/2 an hour. Nev
