Wiring help please
General electrical problems
Louiseryder
Wiring help please
Post by Louiseryder »
Hi everyone
Nh 350 Ariel. My dad has hit a snag he can’t wire the reg box in as he’s not sure what to put the red wire to as the bike doesn’t have a field coil can anyone shed some light on this please?
Re: Wiring help please
The Red wire goes to earth on the bike. The field coil is contained inside the dynamo.
It may be wise for your Dad to seek assistance from a local AOMCC member. You should be able to find someone suitable quite easily if there is a nearby branch of the Club.
Louiseryder
Thank you that has solved that problem. One more question if you wouldn’t mind he can’t find where the amp meter wire goes? There doesn’t seem to be anywhere on the reg box for it to go.
The black wire and the battery wire should both connect to the negative side of the ammeter. Whose regulator is that, the instructions are terrible? Here is a wiring diagram that may help, it covers 1951-58 singles but basically OK for anything back to 1936. Always useful to give the year as well as the model, they didn't change much but they did change over the years.
1301.pdf
(158.82 KiB) Downloaded 26 times
Rick Hughes
Post by Rick Hughes »
That's a wassell positive earth regulator. Diagram
That's a terrible type of wiring Loom Diagram. It would only be useful with one specific Product. Mostly, I have wired the Bike then taped up the Loom Later. I always fit a stop Light. Nev
