Crankcase ventilation
“Two-stroke engines with a crankcase compression design do not need a crankcase ventilation system, because normal operation of the engine involves sending the crankcase gases to the combustion chamber“. I copied this from Wikipedia. If this is correct why does the Arrow engine have a ventilator?
Re: Crankcase ventilation
Other than to admit fuel and air and to expel exhaust gasses I assume. Where is this ventilator?
Trev Sellars
I think he is referring to the chaincase - clutch vent, that sticks up from the crankcases. Not a Vent for the sealed crank area!
Thanks for the response Trev. I purchased the “Breather Pipe Assembly” from Draganfly in April 24. The part number is T124. It looks to be connected to the crankcase unless there is a drilling through the back of the primary chaincase.
As Trev says, it's a chaincase breather, there is a drilling...
Even Porosity can cause Problems with some 2 stroke crankcases and car inlet Manifolds. Nev
