sq4 brake mod
Re: sq4 brake mod
spedo is not driven from the front wheel on the SQ4, part of the brake plate casting buts up against the fork leg so it cant turn, the torque arm mounts on the mudguard mounting studs which are on 1/4 inch high tensile studs. i did not think they were big enough so i arranged it so the the brake plate casting buts up against the fork leg as well .
Re: sq4 brake mod
Well....nadab_sardar wrote: Mon Nov 16, 2026 9:33 am Nice conversion, Ken. A 3.50x19 BSA 8" TLS up front must be a world away from the original SQ4 brake, and it's good that you kept the original forks and wheel so it's all reversible.
Since you say it's now stopping hard on very little lever pressure, I'd bed the shoes in gently before leaning on it too much. New linings on a brand new drum can grab a bit at first, and fresh Avons need a few miles to scrub in as well, so give yourself some margin on the first few emergency stops. It's also worth checking the torque arm mounting and the cable run now and then, as a TLS pulls quite a bit harder than the old brake did.
Out of interest, did you have to change the speedo drive arrangement, or does the BSA hub take it as is?
It's not a 3.50x19, the tyre is a 90/90x19. The tyre size is irrelevant but if you're going to mention it, get it right. I'd also like an explanation of why a cable run needs to be part of a maintenance check.
Also it's obviously not a brand new hub and equally obvious (for other reasons as well as the photo) is that there's no front-wheel speedo drive.
If you're going to deliver advice make sure it's accurate and appropriate. There's more than enough inaccurate rubbish on the internet already.
Administrator
webmaster@arielownersmcc.com
nadab_sardar
Re: sq4 brake mod
noMick D wrote: Mon Nov 16, 2026 9:50 amArtificial Ignorance?nadab_sardar wrote: Mon Nov 16, 2026 9:33 am Out of interest, did you have to change the speedo drive arrangement, or does the BSA hub take it as is?
Re: sq4 brake mod
SPEDO IS NOT DRIVEN FROM THE FRONT WHEEL, SEE PREVIOUS POST
Re: sq4 brake mod
Were you having a bad day Admin?
Re: sq4 brake mod
Are you battling bots? Or is it just dark and persistently raining in your neck of the woods?
Re: sq4 brake mod
All of the abovesimon.holyfield wrote: Wed Nov 18, 2026 2:24 pmAre you battling bots? Or is it just dark and persistently raining in your neck of the woods?
Administrator
Re: sq4 brake mod
well,
it did cross my mind that the post from nadab with the rather odd remarks have some resemblence to text generated by chat gpt
or ?
or ?
- charles.bulloch
Re: sq4 brake mod
Which ever way you look at it, that is a fantastic brake even with the original sls brake plate.
