59 Red Hunter
MarkPhillips
59 Red Hunter
Post by MarkPhillips »
Hi everybody just thought I’d share my bike nothing rare or special. Didn’t go looking for an Ariel just wanted an old bike to fix up something you can work on and make bits for.
Saw my bike on the interweb just down the road a pre unit Brit single and not silly money got to be worth a look I thought.
The bike looked lovely from 10 feet away but was basically unrideable everything needed going through, I don’t think it had been ridden in years.
Promised the old boy I’d take care of her and not to worry, the bike definitely deserved a better life.
But I couldn’t live with that horrible hot dog bun beige saddle yuk. Fortunately it was rotten all pop rivets and fibre glass, ghastly it had to go.
Joined the club and much prefered the look of the older Hunters tractor saddle and exposed rear mudguard, much more my cup of tea.
But it was winter now and the bike was mine so decided to solo saddle the bike.
Decided not to chop the frame about instead make a light weight sub frame to take a saddle and rack that would only attach to the bike using the original fixings for the saddle.
Bonus of this it left lots of space under a saddle me n my mate made to fit the coil and wiring for a Thor spark electronic ignition.
Now I know a lot of you would sooner eat your grand children than move away from a magneto, but sending my pretty useless mag away to some wizard in a shed for months and hundreds of pounds made no sense, a second best idea for a lot more money. And I got to do it myself.
And no I won’t be stranded if my dynamo packs up, I have two Yusa Y4 6V batteries in the the tool kit pod and a 7.2V NIMH battery under the saddle that will run the Thor Spark for a day. With the big brucey bonus the bike starts so easily.
I junked the carb talk about knackered completely worn out, a new one was the only way forward.
I rebuilt the gearbox with much appreciated help from the club just brilliant.
I stripped the useless brakes that came with new shoes and skimmed drums already done but had the contact patch of a dead ant utterly useless. Spent a lot of time bedding in the shoes by hand and after 2000 summer miles they work sort of ok, but I definitely want better.
One thing I’ve done is de imperialise as many of the nuts and bolts as possible, I have a very extensive professional metric tool set so all the dog eared old stuff is replaced with metric stainless and all the the big old chisel rashed nuts replaced and ground down to a metric AF.
I’ve gradually been repainting the bike with mixed results from excellent to not so, even when you get a good result I always seem to scratch it working on the bike clumsy I guess I’m not interested in a show poney I ride my bikes a lot I prefer go over show.
Anyway the bike had been completely repainted back in the 80s plum or crimson looks the same as all other Hunters so no original patina to preserve. Any way lots of filler cracks and rust blisters appearing and even had to weld new steel in to the front mud guard where it had rotted under the filler.
By complete fluke I found Halfords rattle can paint S4 030 was a very very close match, but Halfords paint is about as hard wearing as Lacy knickers on a Rhinoceros and E10 melts it like Nitromors. So I’m trying UPOL professional clear coat, tried some on a test piece that I left in a jam jar of E10 for a day and it came out fine. But a word of warning it takes weeks to go hard and is made of plutonium and mustard gas so care must be taken
The bikes of the road for the winter and I really miss riding her, never owned a bike that got so much attention or got chatting about to so many people.
So far this winter I’ve overhauled the front forks with new seal holders and sprayed them and the head light binnacle. Removed the head and wheel bearings cleaned and regreased. Had the back wheel out repaired the fibre glass chain guard and painted wheel bearings bedded the shoes in again and made an adjustable linkage to give more feel and power I hope.
De rusted the petrol tank with white vinegar amazed how much rust came out but it seems solid sanded the rust blisters back to bare metal and painted.
The engines running lovely but a peek down the bore reveals lots of coke and the top end weeps oil from the cam covers and the the push rod seals, I’m loathe to strip a good running engine but I guess if I don’t I just putting of future problems juries out on this one.
I do however fancy overhauling the Speedo that works well up to 30 then gives up.
I’ll be busy any how can’t stop tinkering.
Cheers Mark.
admin
Re: 59 Red Hunter
Post by admin »
More appropriate in Members' Bikes I think, so moved!
Quite a few controversial modifications here but ultimately it's your bike and you can make it suit all of your tastes no matter what anyone else might think!
