Burman GB mainshaft lenght
david.anderson
Re: Burman GB mainshaft lenght
Post by david.anderson »
Thanks Roger but that is a rigid HT (1954?) not a swing arm. I understood the 1955 HT swing arm was initially fitted with the GB11. I did try a GB39 (same cases as GB11) in my HT and it will not fit. In the swing arm HT the gearbox is much closer to the engine and I had to tilt it back from upright to avoid the timing case bolt. From memory (probably 15 years ago that I tried it) that meant different top and bottom engine plate gearbox bolt hole locations.
The photo of my HT shows just how close the smaller GB 47 outer casing is to the rear frame and timing case to engine plate bolt. There is enough room for primary chain adjustment with very little extra to spare.
Please ignore the incorrect earlier timing cases, modified footpegs etc. I do have the correct parts and will one day correct it but for now I do enjoy riding it on local bush tracks etc.
All the records show that 1954-55 HT were rigid, s/arm arriving for the 1956 season. 9 of the 25 rigid HTs built list the gearbox, all GB11. There is one very early 1956 HT with a GB11 but all the rest on the first few pages of the despatch book list GB47. I wonder how they managed to fit it, there is nothing special listed about the bike, other than a lighting set.
david.anderson
Thankyou Roger. For some reason I have wrongly believed that the swing arm HT was introduced in 1955.
See pics, I think its OK to say that a standard GB mainshaft has the same dimensions as a HT mainshaft.
First pic, HT is the top one.
last pic is the standard GB shaft
another question.
as known, a FWH makes the drive chain out to the left,
done with a thicker collar on the engine shaft and the longer gearbox mainshaft.
This to get all in line.
OK I grasp that, but..
Does the left side swingarm leg point more outward on the FWH models ?
Only difference - I think- are the closed fork ends on the models with the FWH, or is there more ?
Well done Vincent, I had never considered that the s/arms may have different widths but logical when one thinks about it. However on all 3 versions the left side arm is 3-15/16 from the centre line and the right is 3-7/8 away, in other words the left side is offset by 1/16" .
The measurements I have listed in the past for the long plain diameter of mainshafts are from shoulder to shoulder, slightly different to the position you have measured. However when you say 'compared to the standard GB mainshaft' do you mean the 1952-55 standard or the 1956-58 standard ???
david.anderson
While I do not have the SA details for the HT, the chain line on the frame is stated as 4 1/8” left of centreline. The SA mounting is also offset to the left considerably (11/16”) but there is only a 1/16” offset at the top shock mounting points. Does this in anyway suggest that the HT should have the FERC mainshaft.
david.anderson
After looking at my bike I believe the chain line that is referred to is the primary chain line, not the rear chain.
You are correct about the figure being for the primary as it is outside the frame! I have looked through lots of drawings but I don't have the right ones to compute the chain line for the HT, oddly I can do it for the rigid framed HT and I am sure I could for the road models.
