Burman GB mainshaft lenght
Post by Paul Slootheer »
I’ve read Burman used three lenghts of mainshafts on there GB gearbox:
- 1952>1958 SQ, 88,9mm
- 1952>1955 Single/Twin 71,4mm
- 1956>1958 Single/Twin 76,6mm
What models used 73mm?
Re: Burman GB mainshaft lenght
There are 4 mainshafts used in GB gearboxes on Ariels
3629-52 Mainshaft 3-1/2" plain section SQ4 (88.9mm)
3630-52 Mainshaft 2-7/8" plain section Not SQ4 1952-55 (73.025)
3630-56 Mainshaft 3" plain section Not SQ4/HT 1956-58 (76.2mm)
3629-56 Mainshaft unknown length HT
I think someone has made an error in converting to mm, one of the reasons for keeping the imperial units, as it is obvious when an error has been made.
Does anyone know the length of an HT mainshaft to complete the story?
So is it correct that the 1952-1954 shaft is the right one for a 1953 rigid frame?
Yes, the change is to accommodate the FERC in 1956
a HT box has the same housing as a Burman GB but is has a front from AJS / M.
So it has the same mainshaft .
The layshaft in the HT box has the speedo gear cut off as drive comes from the rear wheel.
That one is a mix of a rigid frame Ariel brakedrum with BSA small flange .
Later competition ones frequently used alloy Leader hubs but that was after Mr. Miller took over the bars.
You are correct Vincent, I don't know where I got that information and part number, did I make it up?
Possibly :D
nicely concluded investigation, the advantage of a forum… :D
david.anderson
Post by david.anderson »
With regards to the HT the first few bikes, 1955, were fitted with a GB11 which I understand was mostly the same as the other singles except for the gears and layshaft. The Parts book for 1955 lists the mainshaft for all except the square 4 as 3630-52. The layshaft is 3657-55 for the GB11 only. I also do not know how they fitted the GB11 unless it was not upright but angled back. Anyone got any details or photos of a GB11 in place.
The 1956 HTs were fitted with a GB47 . The Inner case is virtually the same as the VH but the outer casing is the AMC. The mainshaft is VH, but I have not been able to determine from the parts books if 3630-52 or the FERC type 3630-56 is used. The 1956 parts book seems to list the longer mainshaft for all singles but is not definitive as it does not state specifically HT. Is there an addendum to the 56 parts book for the HT. The mainshaft photos by Vincent seem to confirm that the HT is fitted with the shorter 3630-52 mainshaft. The layshaft is AJS, which is the VH layshaft without the speedo gear extension. As such the GB47 layshaft is the same part no as the GB11 layshaft. The AMC components in the outer casing incorporates a clutch operating mechanism consisting of 3 hardened balls which operate between 2 steel pressings in face cam type recesses. One pressing is in the gearbox and a radial extension on the other is attached to the clutch operating cable. There is no provision for adjustment of pushrod end clearance in the AMC box so the adjustment is by the AMC clutch pressure plate which has an adjuster in the centre.
While I previously stated the inner GB47 case was VH, there is an extra tapping for a screw to fit the AMC outer cases, and the part no is 3600-56. All else about the case is the same, just 1 extra screw hole.
Any 1955 HTs with the GB11 out there.
It is difficult to tell from Vincent's picture if the long plain section of shaft is the same length or not, perhaps if they are still handy you could measure them for us? I agree David that according to the parts book as the m/s for the GB47 is not listed as being different it should be the FERC type, however it would not be the first error in a parts book.
The GB11 in the 1955 HT appears to be mounted at the normal angle.
