Ariel arrow
Brianh
Ariel arrow
Post by Brianh »
Help required please.ariel arrow gearbox.i have removed the inner and outer gearbox covers to replace both gaskets, i did not remove the main shaft hence the gears on that shaft come out separately. On rebuilding I seem to have a small spacer, internal diameter the same as the main shaft which I can’t see where it should go. HELP.
Re: Ariel arrow
There are not any spacers inside the gearbox see https://draganfly.co.uk/product-categor ... box-inner/. Someone may have added it to remove some end float. What is the ID/OD/length ?
Pete.Silson
Re: Ariel arrow
Post by Pete.Silson »
Have a look at Draganfly site, they have exploded diagrams of the gearbox.
I can't recall any spacers in the gear cluster. If you post a picture of the offending item I'm sure someone will recognise it.
Brianh
Re: Ariel arrow
Post by Brianh »
Brianh
Re: Ariel arrow
Post by Brianh »
Size of spacer is ID 24mm depth 8.5 mm
Re: Ariel arrow
T857 distance collar for kickstart shaft, The dimensions will be whole fractions of an inch not millimeters. https://draganfly.co.uk/shop/85808/dist ... tart/#T857
Brianh
Re: Ariel arrow
Post by Brianh »
Thanks for that, unfortunately it’s not that, I have that separately together with the spring
Re: Ariel arrow
Well, there is this part https://draganfly.co.uk/shop/85810/dist ... 7187/#T858. Pretty sure that is all from inside the gearbox
admin
Re: Ariel arrow
Post by admin »
Moved to 'two-stroke'! ;)
Brianh
Re: Ariel arrow
Post by Brianh »
Thanks Roger, will check that out tomorrow
