Hello and good evening,
please tell someone the maximum clutch push rod movement disengage - engage.
Its a burman BA panther gearbox but the clutch should be similar or same as the GB.
Thank's a lot - Ralf
ralfpenkert
Re: clutch push rod movement
Be the same as any BAP. Just have about 3/16th free Play at the Hand lever tip and about 1/8th extra travel of the rod after contact. Kickstarter will confirm the Plates have freed up. Take the clutch cover off and Make sure the springs are set so it separates evenly and you can kick it against compression with No slippage. Nev
ralfpenkert
Thanks Nev,
someone told it should be 5/16th which i couldn't get.
Ralf
Ralf
Aim for minimum clearance the reason is that it must not rub and wear away or possibly expand a little and give clutch slip. Details are in all the owner's guides
