58 VH 500 popping out of second gear above 2500-3000 rpm
Re: 58 VH 500 popping out of second gear above 2500-3000 rpm
Well that's not it then! I think shimming the secondary shaft top hat bushing on the case cover side, or the other side?
Danilo Gurovich
Marine City, MI USA
1957 Ariel 500cc
1961 Matchless G12 CSR
1966 Matchless G80s
1968 Moto Guzzi V700
2006 Royal Enfield Bullet
2019 Royal Enfield Interceptor
a Couple of modern Vespas
Marine City, MI USA
1957 Ariel 500cc
1966 Matchless G80s
Might I suggest you measure the endfloat for the mainshaft, layshaft and sleeve gear? There's a lot of expertise in the club (not me!) that has helped me hugely with problems like this...dgurovich wrote: Wed Sep 16, 2026 12:47 pm Well that's not it then! I think shimming the secondary shaft top hat bushing on the case cover side, or the other side?
Is there instructions for accurately measuring end float? I'm new to transmissions and I'm comfortable with assembly/dissasembly, but the finer points are still kind of new to me.
Danilo Gurovich
Marine City, MI USA
1957 Ariel 500cc
1966 Matchless G80s
Marine City, MI USA
1957 Ariel 500cc
1966 Matchless G80s
This should help. The guage is called a Dial Test Indicator here in the UK - there is a plunger which moves in and out and makes the needle go around on the gauge to show you how much the plunger has moved. In this picture I have the plunger in contact with the end of the sleeve gear.
DTIs are used with a magnetic stand, which is sitting on one of the engine plates.
You push the shaft in one direction, set the gauge to zero, and use some sort of lever to push the shaft in the other direction and measure how much it moves.
I have that tool. I'll dig in!
Danilo Gurovich
Marine City, MI USA
1957 Ariel 500cc
1966 Matchless G80s
Marine City, MI USA
1957 Ariel 500cc
1966 Matchless G80s
