Pushrod rubber size how much to remove
Rick Hughes
Post by Rick Hughes »
Im slowly collecting the bits and bats to build my 2nd engine I call it my slow engine as apposed to the other the fast engine ,,hopefully with its low compression piston and standard cam and oil pump, rockers that will take a valve lifter. It will be a better type of engine for me kick over and ride as I would like .
I got a full gasket set and the pushrod rubbers are too tall
Iv read as many searched posts on here as I can but can't find
How much clearance before tightening the head down currently its 5mm my engine is a iron head vh 500 and do I do both a little or just say the top ones
How do you cut them down I have visions of hacking them with a stanley blade but my brain can't fathom a more exact way..can they be ground or sanded ? or is their a proven method
Re: Pushrod rubber size how much to remove
Iron head? I always just crush them down with tightening the head bolts. (Even the original Ariel ones - from my Ariel gasket sets - are much too tall).
I agree 100% with Simon. It has worked well enough for me for over 50 years but you do need to change the rubbers from time to time.
The original brand was Thyrco from memory. I have one bike where the rubbers have expanded and gone soft. Still not leaking but Look terrible. Most of the replacement ones I've had for a while have gone a bit hard. Tighten the Pushrod side head bolts ahead of the Spark plug side to keep everything level and better aligned.. Nev
