1952 crank plug
Kev.Leaverland
1952 crank plug
Post by Kev.Leaverland »
Hi Im trying to get my 1952 VH back on the road after a 20 year sleep. I need to know what size long socket I need to remove the oil purifier plug. I think it's 3/16 whitworth. I'm sure someone will be able to confirm this. Thanks
Re: 1952 crank plug
It's a BS size. Needs to be a good fit or you might round it off and be in strife. A sharp hit om the socket or the Hex with a brass drift can make it easier to move. It doesn't need to be eye- wateringly tight. Just enough so it won't undo. The gunk inside can be pretty Hard if it's been there for a while. Nev
garycullen
Re: 1952 crank plug
Post by garycullen »
Adding to Nev’s advice try and use a good condition 6 sided or hex socket. The multi faced sockets will round the bolt off if it has been in there for a while.
A sharp tap with a ball pien hammer first on the top will also assist to loosen the threads.I keep a bsf socket unused for anything else just for this job.
Gary Cullen
Forrest Hill
Auckland
Antipodes
1946 VB600 rigid Tele
1933 Austin 10
Pete.Silson
Re: 1952 crank plug
Post by Pete.Silson »
I use a slim 7/16" AF six-sided socket with the end ground flat to reduce the internal chamfer. This sits flush to the sludge trap flange and perfectly into the flywheel hole. It has worked successfully for me on several previously user-mangled sludge trap nuts - probably because it engages on the part of the nut not previously reached. Also, I always use a T-bar to keep the socket square on the nut.
...and before anybody comments on using an AF socket on a BSCy bolt. Standard Whitworth spanners are a relatively loose fit on bolts (to make them easy to use). The 7/16 AF is about 008" tighter than a 1/4 BSF socket and ensures a nice snug fit on the bolt.
Re: 1952 crank plug
Post by Julian Murphy »
Have a look at this thread from 2023, where I asked the same question as you.
viewtopic.php?t=13307.
Re: 1952 crank plug
You can also play with an 11 MM socket as an option and ARC weld on some square if you get desperate. Protect the rest from splatter with big washers etc. Have the Motor in Pieces for that sort of thing. Nev
Kev.Leaverland
Re: 1952 crank plug
Thanks for all of your input. Eventually got it out using a 6 sided 7/16 socket. Pleased to report that after all my faffing about the sludge trap was clean. Still it pays to check these things.
