Front footpegs needed please
Rick Hughes
Post by Rick Hughes »
I dont suppose any one has a set of front footpegs including the bar that goes through to the other side
Mine had rear sets on which was probably good for racing up a hill but not for sedate riding.
My cases have a blanking rubber bung in
I
Re: Front footpegs needed please
What machine are we talking about? Ariel footrest arrangements vary a bit.
Rick Hughes
My engine is a 1938 vh 500.
Draganfly have the bits you need:
https://draganfly.co.uk/product-categor ... footrests/
You need the two footrests, the two footrest supports, the footrest tie rod and the spacer that goes between the gearbox plates behind the engine. To fit them, you will have to remove the primary drive as the LH footrest support won't go through the aluminium case from the outside - it's not difficult though. The spacer fits around the footrest tie rod to stop it squashing the engine/gearbox plates.
Rick Hughes
Thank you Simon that's a big list.
Ill work on it.
Rick Hughes wrote: Sun Jul 12, 2026 10:01 pm Thank you Simon that's a big list.
Ill work on it.
Wait a few days - you might find someone's got some bits hidden away in a box somewhere...
The only thing I've got knocking about is a spacer I think.
Rick Hughes
Iv managed to buy two pegs and two cones I made a tie bar and a spacer
